What are the effects of dividing the VCO output by 2 on output jitter?
jfyan
Full Member level 2
Full Member level 2
shanghai,china
hi all,
jeff
Re: about jiiter
You have to be more clear on your doubt. If it is very low frequency signal at the output of VCO then jitter is not much.
If you need more details, don't hesitate to contact me.
Regards,
N.Muralidhara
CRL-BEL
    jfyan
about jiiter
Jitter will remain the same.
Think of divide by 2 as eliminating alternate edges. The remaining edges will have same jitter as from original source, unless the divider is adding more jitter.
    jfyan
Re: about jiiter
that depends which kind of vco likely to be desigh actually lc vco is having less jitter compare to ring vco
