Re: i want to drive a stepper motor at 8K rpm is that realis
This is very high. Check the data sheet for your information. Stepping motors are stepped between adjacent angles and stopped there. If you try to step too fast, the rotational inertia of the motor will carry it beyond the desired d theta/ d time rate and you will get pot luck on the shaft angle.
I once amused myself by taking a set of three phase synchros and giving the transmitter part a sharp twist which exceeded the system d theta/d time limit and the output indicator would rev up to high rotational speed.
I don't think it is possible. You cannot energize the field that fast and produce enough energy to move the shaft. Even if you drive it the field at 8K the shaft will not rotate. Most high speed motion is done with DC motors and encoders if exact movement is required. There is of course a ramp up/down speed with DC. And if you want to hold a single posistion like a stepper their are ways to do that too.
8000 rpm = 133.3 rps
assuming u r using a 1.8°/step motor, i.e., 200 step/rev --> u need 200 * 133.3 = 26660 step/sec. This is extremely high. I think u can not acheive this steps rate easily. Also, for very high speeds, u will have to trade off any torque for this high speed.
