Cadence IC5141 installation error - on CentOS5
roli
Full Member level 5
Full Member level 5
'SiliconWafer' Island
centos ic5141
On CentOS5 (RHEL 5 equivalent), I get the following errors during installation of Cadence IC5141 (IC v5.141):
Are your selections correct? [y/n] y
Generating detailed installation data...
Determining available disk space
sort: open failed: +2: No such file or directory
Determining required disk space
Disk checks successful
The following media is required:
IC5141 lnx86 P/N 356-70352-0501 CDROM # 1
IC5141 lnx86 P/N 356-70352-0502 CDROM # 2
IC5141 lnx86 P/N 356-70352-0503 CDROM # 3
Press [Return] to proceed, q to quit :
Checking for IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 .........
Extracting control programs .........
Updating package installation information.....
Checking data files...
Executing control programs (pre-load) ...
sort: open failed: +3: No such file or directory
expr: syntax error
SL-8: No information available on :.
Call the Cadence Customer Response Center (CRC) at 1-800-Cadenc2
(1-800-223-3622) to get the right /usr/export/applic/cadence/IC5141/install/tmp/mediaMap.lnx86 file.
Scoured the Forum for similar problem reports. There were a couple of similar reports here in EDABoard, but none of the hints really helped.
Tried to install "ncompress" RPM - but that didn't help ...
Anybody encountered this ?
TIA
cadence ic5141 centos
give me a days time.
i have succedded in installing IC5141 on RHEL 5.1 and scientific linux 5.1 from the original installation media. no tar ball makeing and no modification of install script.
i have solved ur error message.
hock
centos5 cadence
hock
Thanks much !
Eagerly awaiting your advise ... :) ...
ic5141 centos
1. Verify if gzip, bzip2, zip, unzip rpms are installed.
2. Make symlins to gzip as compress and gunzip as uncompress in a dir which is included in PATH.
3. Try to figure out what file/directory is missing. Most of uncompressors can be simlinked to gzip/gunzip.
cadence centos 5
As I mentioned I've added the 'ncompress' RPM - but that didn't help.
Do you suggest to delete original 'ncompress' installation, and simlink compress/uncompress to gzip/gunzip ?
How crucial is bzip2 ?
BTW - my shell is 'tcsh' (not the default 'bash') - Can that be the cause ?
ic5141 installation
Add following to your .tcshrc:
setenv _POSIX2_VERSION 199209
Reactions: jlgr
    jlgr
centos cadence
This solution worked perfectly !!!
Thank you VERY much !!!
More details in this thread -
[ especially note "lagos.jl" post ... ]
ic5141 on centos 5
Hello guys....i had the same problem with IC5141 on Centos 5.
I didn't find where the .tcshrc file is located..... can anybody help me? thanks....
install cadence ic centos 5 sort
OK...Thanks a lot...but i can't run IC5141 on Ubuntu 7.10.....I'll try an older linux vesion, like fedora 4.....
cadence syntax error
Hello !
Did yu succeeded to install ic5141 in centos 5 ??? How ? That option does not work !!!
cadence ic5141 installation procedure edaboard
Hello.
I have some problem during installation of the ic5141 on CENOTS 5.2
Although upper error is occurred , IC5141 is well installed by your help.
but, I have another problem.
when I execute icfb& , following error is occured
"/tools2/cadence/cds5/tools/dfII/bin/icfb.exe: relocation error: /tools2/cadence/cds5/tools/dfII/bin/icfb.exe: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference "
all the environment variables are set in the .cshrc file.
Do you know how to solve this problem ?
Thanks in advanced.
