Help me out with a cross clock domain design
EDA_hg81
Advanced Member level 2
In my design, a local clock is generated by a clock divider, which looks like follow:
process ( iARM7_CLK )
begin
if ( rising_edge( iARM7_CLK ) ) then
spiclkcon <= spiclkcon + 1;
if ( spiclkcon = spiclk_gen ) then
spiclkcon <= x"00";
spiclk <= not spiclk;
elsif ( spiclkcon = x"32" and spiclk = '0' ) then
.. check the data from ARM7 CLOCK domain…
But I have to capture data generated in ARM7_CLOCK domain and have to send data back to ARM7 clock domain.
My question is:
What is the proper way to do those ideas? What I should do to keep those data are valid when they transfer clock domain.
I can not use buffer which is driven by two clocks.
Thanks.
Re: Cross clock domain
whato you should do is keep using your , let's call it system clock, and the use your devided clock as clock enable.
if risinge_edge(sys_clk) then
if divide_clk = '1' then
put your logic here;
your outputs are now aligned with system clock.
pay attentio your outputs to your domain are now allign with sys_clk, and not divide_clk. so you need to shift them.
    EDA_hg81
Cross clock domain
it is not really CDC since you using only one clock to produce divided clock, both of those clocks will be in same phace.
CDC means when you are crossing domain between two clocks and there is no any relationship between those clocks
    EDA_hg81
                     spiclkcon <= x"00";
                 elsif (  spiclkcon = x"05" and  spiclk = '0' ) then
                     case readstatus is
                          when x"00" =>
                              if (  iSD_BUF(7) = '1' ) then
                                   command <= command09;
                               readstatus  <= readstatus + 1;
                              elsif (  iSD_BUF(6) = '1' )then
                              end if;
Do you think code like above is right?
Cross clock domain
looks about right, but I was told you before, you should separate your processes, make code more readble, and also make compilier job easy. Also when you read your timing report, it makes more easy to analyze when you have more structured code
good lack
    EDA_hg81
Thank you all for help.
