Theoretical energy minima for analog to digital conversion
raghav
Junior Member level 3
What is the minimum energy required for analog-to-digital conversion? Is there a lower limit?
Upper bound is infinity. That is because, the "analog" sample can always be "dissipated" before converting it to "digital" data. As such. corrupted "analog" sample means erroneous data. So, the upper bound is infinity. Meaning, you can spend all you energy in sampling and still not "live" to see the fruits. So that brings me back to the question. Is there a lower limit?
Re: Theoretical energy minima for analog to digital conversi
How do we go about computing that? As in, does it not depend on the topology of the "converter" itself? What say?
    raghav
