what is gfsk modulation
FRACTAL
Newbie level 5
Newbie level 5
what is gfsk
What is GFSK modulation and why used for BLUETOOTH
gfsk modulation
tihs might help you
Reactions: woolive
    FRACTAL
    woolive
what is gfsk?
Now a days which modulation is used for BT
what is a gfsk modulation
this table give you cleare idea about different modulation scheme for different data rate
    FRACTAL
whats is gfsk
which is the best architecture for Bluetooth receiver
• gfsk modulation
for the bluetooth ganerally Low IF structure is used because most of the power in the base band near around low frequency.
hope helps.
    FRACTAL
