How to check if DTMF IC is working properly?
joe1986
Full Member level 4
Full Member level 4
how can i check if my DTMF IC is working properly or not...........any idea????
Re: DTMF CHECK
You need to feed it two sinewave frequencies, one from the lower group and one from the upper group of 4 frequencies simultaneously and verify the correct 4-bit result at the digital decoded output of the chip. Depending on the chip type, you may need to take the 2 dB +/- 1 dB signal level difference into account.
Good luck !
Hans
Re: DTMF CHECK
hi nandhu015 .................do u have any diagram which shows how to connect it to the telephone???
DTMF CHECK
Which DTMF IC do you use?
You can connect it with a MT8888 to check if it transmit/receive right or wrong.
Re: DTMF CHECK
THANK a lot doctor laktronics........................DO U HAVE THE MAY 07 edition of EFY..........there's a file called "WIRELESS TEXT MESSAGING OVER MOBILE/LANDLINE...........????
DTMF CHECK
use oscope to view the dtmf signal ..
Re: DTMF CHECK
I just remebered, your 5V supply should not have a safety earth connection, since telephone line is already earthed through +ve of the battery. I don't have the May Issue, you may get it from their site?
Regards,
Laktronics
Re: DTMF CHECK
hi .....doctor laktronics there is one problem ...........the site is asking for username and password of subscribers..............actually i subscribe for ELEKTOR ELECTRONICS...........and not EFY ...................are you a subscriber???
Re: DTMF CHECK
joe1986 said:
the IC IS DTMF 8870..................ITS ACTING AS A DECODER
Have you made a test board?
If you have, it's so easy.
Connect your phone line to the input of 8870. Call from other phone. Hook up the phone which connect with 8870. Then press some numbers from the caller phone. If your test board can receive what you press , it's working well. That's all.
Regards.
Re: DTMF CHECK
whts a TEST BOARD AND HOW TO MAKE IT???
