How to change OFDM program to MIMO-OFDM one in Matlab?
totohaha
Newbie level 2
Newbie level 2
I have finish an OFDM program in Matlab, now I wan to modify it into a MIMO-OFDM, could anybody tell me where I should modify? channel matrix?
MIMO-OFDM
now, if you want to modify to a MIMO-OFDM, you should research Space time code or V-BLAST ... because these relate to MIMO. You have finished OFDM program that is you finished modulating/demodulating,IFFT/FFT and fading channel. However, to finish MIMO-OFDM you also should read Maximum Likelihood. after investigated i think you have the ideas to advance your program.
Goodluck!
Re: MIMO-OFDM
removed!
some channel coefficients:
(exp: exponential or SUI4 or Cost207 or ...).
Re: MIMO-OFDM
hi totohaha , just split the input vectors may be as alternate bits depending on the number of transmitters ,transmit through the fading channel,on the reciver side detect the bits using V-BLAST algorithm,will work fine
Re: MIMO-OFDM
hi
i think ur que is where to apply mimo in mimo-ofdm system?
Added after 34 seconds:
hi
MIMO-OFDM
Hi totohaha,
Could you please send me the OFDM syntax, because I am working on it, and I have difficulties to design an OFDM system with multipath fading.
Very thanks in advance.
sh.
Re: MIMO-OFDM
I am a telecommunication students and interested in OFDM.
I am still studying OFDM. Please may you send me your MATLAB codes for OFDM? so that I can even see the plot for Eb/No versus SNR or BER performance or any other performance analysis.
Re: MIMO-OFDM
What is the differences between MIMO and MIMO-OFDM and their advantages... give some points...
IN what way MIMO-OFDM is efficient than MIMO...
iam thinking we hve to modification at the transmitter side... that is before modulation...
MIMO-OFDM
can you guys upload the programs made?
Re: MIMO-OFDM
you should divide the transmitted data into Mt bit stream. after modulation with OFDM you should transmit the modulated signals through MIMO channel
Re: MIMO-OFDM
1. Why precoding requires knowledge of the channel state information (CSI) at the transmitter.
2. what is the importance of CSI and Wht are their parameters?
pls help....
MIMO-OFDM
al salam 3alycom,
i want to ask that i use dvbt-sim but the input to this system is come from birnolli source but i want to enter the output from video source so how can i convert the output from Video source to mpeg stream on matlab simulink?
thanks
Re: MIMO-OFDM
hi, Please upload your MIMo-OFDM matlab code?thanks for advance..........arif rahman
MIMO-OFDM
hi to all,
i am doing project on MIMO SFBC CI OFDM. please will you say how to implement receiver part in MATLAB.
please will you forward any matlab code related to this. At least will you send steps for implementing this.
thank you very much in advance.
srinivas
srinivasarao473(at)gmail.com
Re: MIMO-OFDM
Hi
I have done some work on MIMO-OFDM. I am attaching a file as well. Can any body tell me how can i used multiuser using TDD in this script.
Re: MIMO-OFDM
Can you send me the exponential and sui and cost207 models details to my mail bvrchowdary@gmail.com. plzzzzzzzz i need them urgently. help me plzz. other wise inform to me where can i get more infomation about them. if you have any matlab code also i need them plzzzzzzzzzzzzzzzz.
salam2000 said:
removed!
Re: MIMO-OFDM
hi i need mimo- ofdm matlab code... reply asap...
Re: MIMO-OFDM
Please anybody send me MATLAB codes for OFDM? so that I can even see the plot for Eb/No versus SNR or BER performance or any other performance analysis.
my email-id is swati_juneja347@yahoo.com
