Code for division in VHDL
division in vhdl
It's a pipeline divider.
Reactions: wick25
    V
    wick25
division en vhdl
Just to elaborate
You can also edit the specifications of pipline divider by going to CORE GENERATOR
(a tool from Xilinx within project navigator)
And then go to MATH FUNCTION and then DIVIDERS
From there u can change the width of input output ports. and the output type (fractional or remainder)
vhdl code for division
If you need divide by two it is simple.
signal divby2:std_logic;
if (clk'event and clk = '1' ) then
divby2 <= divby2;
end if;
To get div by 4 use divby2 as clock and take one more signal and continue. If you want more details post your question with details.
Regards,
N.Muralidhara
Reactions: wick25
    wick25
pipelined divider vhdl
--Hi
--a division 32 by 32 in 32 cycles
--scuse me for french inside....
--best regards
-- Division.vhd
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
library IEEE;
use IEEE.Std_Logic_1164.all;
use IEEE.Std_Logic_arith.all;
use IEEE.Std_Logic_unsigned.all;
Entity Division Is
    port(
        Clock            : in  std_logic;
        Reset            : in  std_logic;
        Load            : in  std_logic;
        Numerateur        : in  std_logic_vector(31 downto 0);
        Denominateur      : in  std_logic_vector(31 downto 0);
        Ready              : out std_logic;
        Quotient           : out std_logic_vector(31 downto 0);
        Reste              : out std_logic_vector(31 downto 0)
end;
architecture Division_RTL of Division is
constant ALL_ZERO    : std_Logic_vector(31 downto 0) := "00000000000000000000000000000000";
signal     ni        : std_logic_vector(63 downto 0);
signal     sub       : std_logic_vector(63 downto 0);
signal     n         : std_logic_vector(63 downto 0);
signal     i         : std_logic_vector(63 downto 0);
signal     d         : std_logic_vector(63 downto 0);
signal     d_int     : std_logic_vector(31 downto 0);
signal     counter   : std_logic_vector(5 downto 0);
--    attribute syn_keep : boolean;
--    attribute syn_keep of d_int, N : signal is true;
signal     ReadTempo         : Std_Logic;
begin
    Ready <= ReadTempo;
    NI(63 downto 0)        <= ALL_ZERO & Numerateur;
    D(30 downto 0)    <= "0000000000000000000000000000000";
    D(62 downto 31)    <= d_int;
    D(63)        <= '0';
    Quotient        <=n(31 downto 0);
    Reste        <=n(63 downto 32);
    Process(Reset, ReadTempo, n ,d )
    Begin
        If Reset = '1' Then
            sub <= (Others=>'0');
        ElsIf ReadTempo = '0' Then
            sub<= n - d;
        Else
        End If;
    End Process;
    Process(clock, reset, ReadTempo)
    begin
        If Reset = '1' Then
            n(63 downto 0) <= (Others=>'0');
            D_Int(31 downto 0) <= (others=>'0');
        ElsIf Rising_Edge(Clock) Then
            If load='1' Then
                n(63 downto 0) <= NI(63 downto 0);
                D_int(31 downto 0) <= Denominateur(31 downto 0);
            Else
                If ReadTempo ='0' Then
                    n(63 downto 0)    <= I(63 downto 0);
                End If;
            End If;
        End If;
    End Process;
    Process(Reset, Sub, n, ReadTempo)
    Begin
        If Reset = '1' Then
            I <=  (others=>'0');
        ElsIf ReadTempo ='0' Then
            If Sub(47)='1' Then
                I(0)    <='0';
                I(63 Downto 1)    <= N(62 Downto 0);
            Else
                I(0)    <='1';
                I(63 Downto 1)    <= Sub(62 Downto 0);
            End If;
         Else
            I <=  (others=>'0');
         End If;
    End process;
    Process(clock,reset)
    Begin
        If Reset = '1' Then
            counter    <="111111";
            ReadTempo        <= '0';
            If Load = '1' Then
                Counter    <= (Others=>'0');
                ReadTempo    <= '0';
            Else
                If counter="011111" Then
                    counter    <="111111";
                    ReadTempo        <= '1';
                Elsif counter="011110" Then
                    counter    <=counter+'1';
                    ReadTempo        <= '0';
                Elsif counter="111111" Then
                    ReadTempo        <='1';
                Else
                    ReadTempo        <='0';
                End if;
            End If;
        End If;
    End Process;
End;
vhdl division code
you can test , this code :
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
use IEEE.STD_LOGIC_ARITH.all;
entity division is
    generic(SIZE: INTEGER := 8);
    port(reset: in STD_LOGIC;
        en: in STD_LOGIC;
        clk: in STD_LOGIC;
        num: in STD_LOGIC_VECTOR((SIZE - 1) downto 0);
        den: in STD_LOGIC_VECTOR((SIZE - 1) downto 0);
        res: out STD_LOGIC_VECTOR((SIZE - 1) downto 0);
        rm: out STD_LOGIC_VECTOR((SIZE - 1) downto 0)
end division;
architecture behav of division is
    signal buf: STD_LOGIC_VECTOR((2 * SIZE - 1) downto 0);
    signal dbuf: STD_LOGIC_VECTOR((SIZE - 1) downto 0);
    signal sm: INTEGER range 0 to SIZE;
    alias buf1 is buf((2 * SIZE - 1) downto SIZE);
    alias buf2 is buf((SIZE - 1) downto 0);
begin
    p_001: process(reset, en, clk)
    begin
        if reset = '1' then
            res <= (others => '0');
            rm <= (others => '0');
            sm <= 0;
        elsif rising_edge(clk) then
            if en = '1' then
                case sm is
                when 0 =>
                    buf1 <= (others => '0');
                    buf2 <= num;
                    dbuf <= den;
                    res <= buf2;
                    rm <= buf1;
                    sm <= sm + 1;
                when others =>
                    if buf((2 * SIZE - 2) downto (SIZE - 1)) >= dbuf then
                        buf1 <= '0' & (buf((2 * SIZE - 3) downto (SIZE - 1)) - dbuf((SIZE - 2) downto 0));
                        buf2 <= buf2((SIZE - 2) downto 0) & '1';
                    else
                        buf <= buf((2 * SIZE - 2) downto 0) & '0';
                    end if;
                    if sm /= SIZE then
                        sm <= sm + 1;
                    else
                        sm <= 0;
                    end if;
                end case;
            end if;
        end if;
    end process;
end behav;
division algorithm in vhdl
use counter
Reactions: wick25
    V
    wick25
vhdl pipelined divider
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
--  Uncomment the following lines to use the declarations that are
--  provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity div_binary is
Port (
            ina : in std_logic_vector (15 downto 0);-- range 0 to 99;
          inb:  in std_logic_vector (15 downto 0);-- range 1 to 9;
         quot:  out std_logic_vector (15 downto 0);-- range 0 to 99;
         rest : out std_logic_vector (15 downto 0));-- range 0 to 99 );
end div_binary;
architecture Behavioral of div_binary is
signal a,b: integer range 0 to 65535;
begin
a <= CONV_INTEGER(ina);
b <= CONV_INTEGER(inb);
process (a,b)
variable temp1,temp2: integer range 0 to 65535;
variable y :  std_logic_vector (15 downto 0);
 begin
 temp1:=a;
 temp2:=b;
 for i in 15 downto 0 loop
 if (temp1>temp2 * 2**i) then
 y(i):= '1';
 temp1:= temp1- temp2 * 2**i;
 else y(i):= '0';
 end if;
 end loop;
 rest <= CONV_STD_LOGIC_VECTOR (temp1 ,16);
  quot<= y;
 --quot<= conv_integer (y);
  end process;
end Behavioral;
HI.
abhi_459, regarding your code for division.
I'm just curious. I'm trying to modify it a bit to accommodate a 17 bit divisor and dividend but errors keep popping up whenever I simulate it on Modelsim. I changed all the 15s to 16s, the 65535 to 131071, and the one 16 to a 17 (where the remainder conversion is). Any thoughts?
Re: vhdl division code
If you want to divide with an odd number then you could use the following way, this is an example to divide by a factor of 5 but it can be used for any number (7,9,11,13....)
-- Divide clock by 5
library IEEE;
entity clk_div5 is
  port (  clk		:in std_logic;
	  clk_out	:out std_logic:='0');
end clk_div5;
architecture Structural of clk_div5 is
  signal set_clk_out, reset_clk_out: std_logic:='0';
  signal counter :std_logic_vector(2 downto 0):="000";
begin
process (clk)
 begin
	if (clk'event and clk='1') then		-- rising edge of clock
		if (counter(2)='1') then		-- check for counter=4 (100 binary, but we check only bit2)
			counter<="000";			--	reset counter value
			set_clk_out <= not reset_clk_out;	-- set clk_out to 1
		else counter<=counter+1;
		end if;
	end if;
end process;
process (clk)
 begin
	if (clk'event and clk='0') then		-- falling edge of clock
		if (counter(1)='1') then		-- check for counter=2 (10 binary) and since we are in a falling edge this is actually 2,5
			reset_clk_out <= set_clk_out;    -- set clk_out to 0
		end if;
	end if;
end process;
clk_out <= set_clk_out xor reset_clk_out;
end Structural;
This is the simulation result
https://obrazki.elektroda.pl/98_1290037522.gif
The attachment includes the code , test-bench and simulation result
Alex
  • clk_div5.zip
Reactions: sanju_
    sanju_
Re: vhdl division
Anyone have a VHDL code for a programmable divider which can change the dividing frequency by a integer number from outside (Let's say DIP switches will give the dividing frequency)
I suspect he means a frequency divider. In which case you use either the DCM/PLL on the fpga, and then configure that. OR you implement a prescaler (counter), and use that to divide. The counter approach should be particularly easy to write yourself...
Division is multiplication and is sometimes possible to replace by multiplication. You just have to find a way to comfortably get the inverse of the B (say C) in the divisions A/B and then perform a A*C. But this is not necessarily always obvious.
A different solution is to check the existing division algorithms. There is a long history in the theory of binary dividers and I most like the Booth algorithm for its theoretical insight. Go take a look at this algorithm -- you shall find it useful. I found it here: http://people.ee.duke.edu/~sorin/prior-courses/ece152-spring2009/lectures/3.3-arith.pdf
but you can google for diferent presentations.
This is an inherently parallel algorithm -- so it is parallel, most-probably low frecquency and expensive in resources. There are bit-serial variants byt you seem to need something of the first kind.
Have good luck with your task/
@ mejdi....
thanks for this division code....
sir i also needed the sin(X),cos(X),tan(X)and the exponential function ........
please help me if know this ..........
thanks and regards
grajput
