Medtronic said:Hi all:
i need to design a power supply with 24v input and 5v output with 5A
please can any one help
How do you regard posting exactly the same question in two EDAboard forums within ten minutes?cross posts are strongly unwanted. They're an unuseful load of EDAboard forum areas
After all I checked again the BD911 will do the job.[/img]chrismicro said:The BD911 max is 3amp an you can leave out the second 7805 you can also connect your first 7805 directly to GND then you will have 5V only but the 2N3055 is easy to get I only used the BD911 for the smaller package.
