Explain me what are the pins highlighted in the figure,
mouzid
Full Member level 5
Full Member level 5
regardig VCO Question
Hi all,
Could someone explain to me what are the pins highlithed in blue in the figure.
Thanks in advance.
Re: regardig VCO Question
hi
it seems that the inputs to delay cells have 2 pair diff-inputs, one is from the previous outputs and the other from the other delay cell's outputs. you can find this vco's architecture in jssc paper in terms of multi phase or negative skew vco.
good luck
jeff
    mouzid
Thanks Friend,
Could you provide the title of the paper ?
Thanks in advance.
