UroBoros
Advanced Member level 2
![Advanced Member level 2](/styles/images/ranks/glevel2.gif)
- Joined
- May 5, 2004
- Messages
- 642
- Helped
- 19
- Reputation
- 38
- Reaction score
- 8
- Trophy points
- 1,298
- Location
- Cochin - India
- Activity points
- 6,463
multiplexing display mcu
Hello
I am doing a system with 8 numbers of 7 segment digits. common cathod ,directly driven from PIC port pins. Usually for systems with 4 digits what I do is a use a 300R resistor series with MCU port pins and timing I adjust by trial and error and it used to be ok.
But here what ever I do with timing I am not getting a bright display. I am doing display on intrrupts. The series resistor I tried by reducing to 220. No substantial improvement.
Can somebody help me with series resistence calculations and timing requirements on 7 segment disaplays? Currents to be incresed to compensate multiplexing. But how much with a 25ma PIC pin? please.
There must be a relation between supply voltage , Ontime ,offtime etc.
Picstudent
Hello
Picstudent
