Microcontroller elevator control system
Medtronic
Full Member level 5
Full Member level 5
Egypt
medtronic2050.blogspot.com
Hi All
i need to design an elevator control board with a microcontroller Atmel89xxx or PIC16Fxxx can any one help me... any advice or information will be great
MedTronic
elevator control using microcontroller
It's quite simple. Please details so I can help you.
(Will you use a Matrix kerbord or the Serial bus for the control ?
How many motors will you use ?
How many floor ? )
elevator microcontroller
thanks too much for replay
let 16 floor and matrix and (or) non matrix keyboard examples
i need some detailes about elevator system (what is the door lockes,levels,slow timer,fast timer,... etc
thanks again
elevator control using 8051
hello.
Anyone please help me?
I'm doing 9 flour elevator and use at89c52. But I can't write a program. please help me?
microcontroller of elevators
What you need to acquire first is the logic diagram of a certain elevator system.
It is like designing a traffic management system but much simpler.
8051 control system
tumee said:
hello.
Do you want someone to write it for you? Sounds like a homework assignment, you're supposed to figure it out. The 8051 is very old, should be lots of code examples on the net.
Hint, try drawing a flowchart to help visualize the program.
Hint2 an elevator is a "state machine"
https://en.wikipedia.org/wiki/Finite_state_machine
elevator control system using microcontroller
any code example for elevator using 8051
i am doing elevator project.i want to know that if i am interfacing led dot matrix display with pic ic, either i have to use 74hc373 &ic 2803 or not.
