ZTP 2.1.0 provides the following features:
Industry standard, RFC compliant protocols
Core protocols: IPv4, TCP, UDP, DHCP/BOOTP, ICMP, IGMP, ARP, RARP
Additional protocols: HTTP, TFTP, SNMP, TELNET, SMTP, DNS, TIMEP, PPP, SNTP and HDLC
Optional protocols: SSL server, SNMP V3 and HTTPS
FTP server and client using an embedded Flash file system supporting multiple disk volumes
Local or remote runtime debugging OS command shell
Ethernet, UART, I2C, SPI, and RTC peripheral driver support
Based on ZiLOG’s real-time kernel, RZK with inter-thread communication and synchronization
Easy configuration options for stack and the kernel
ZTP 2.1.0 supports the eZ80F910300ZCOG ROHS compliant kits.
Supports dynamic memory allocation as a result of which there is a significant reduction in default RAM requirements
Improved Technical documentation
Source code for all peripheral drivers (UART, EMAC, I2C, RTC, and SPI) and flash drivers is part of this package. The EMAC DDK template is also part of this release.
Built on ZiLOG’s Integrated Development Environment, ZDS II – IDE
Http Basic and MD5 digest authentication
SMTP MD5 Digest authentication
PPP CHAP authentication support
Rabbit semiconductor
SNMP 2.02 available here for customers using Dynamic C 9.50.
