LED PWM + BUCK with constant current
bauerbach
Newbie level 3
Newbie level 3
mc34063 led driver
I need to drive ~10 luxeon LEDs at 750-1000mA off the standard 12v current.
but when I use the various online calculators to find the resistor value, they all say I need a massive resistor for that current...
Ive been looking for formal drivers, but they all seem to be for AC input.
what are my options for driving these without overheating a resistor?
mc34063 led
Instead of power-wasting resistor(s) design PWM constant current source and drive LED(s) from there ..
Regards,
IanP
constant current pwm
well that sounds great, but how do I do that?
Added after 13 minutes:
ok, I did some homework and found this while searching what you said
seems very simple; my only question is that the Q2 mosfet says its the limiting factor, the unit they used there, how many LEDs could I support around 750mA? at 3.7volts each, I assume my best choice is to run them in series of 3 to maximize the native voltage. still then, what would such a circuit handle?
pwm constant current source
You mean need to light 10 LEDs from car battery, right? And 10 LEDs at the same bunch, or several bunches? 1A max, OK, but how about the voltage drop and max current of each LED?
nguyennam
pwm constant current circuit
Hi bauerbach,
May be this will be helpful to you:
see attachment or this link:
Good Luck Linoko
constant current source pwm
Can't you not use LEC driver chipset from Linear or National or Maxim? Also soanar.com.au sells an LED driver for Luxeon LEDs.
led driver mc34063
Ill check those places out.
the LEDs are 1000mA max I think; Id be ok with 750mA even, but I want some headroom, 3.7volts each
it would be all of them together. and need to have 2 circuits, 1 to light them up at 750-1000mA and another for the dim lighting of maybe 250-350mA. Tail light application, so thats the need for 2 output levels. so either 2 circuits for each output, or a signal line that can change the constant current...
Added after 11 minutes:
looking at that, I think it might be a real option, small, inexpensive and if I understand the specs right, I could put 2 of them in parralel, and by powering on the 2nd one, would double the brightness from 350mA to 700mA; is that right?
"Parallel Operation for LED Current > 350mA"
mc34063a led
Hi All,
Any idea to implement Buck step-down constant current converter for LED supply (350mA-700mA) but with also PWM for dimmering?
It is suppose that there should be two frequencies involved... PWM (hundred of Hz) and Buck Switch ( KHz ).
Also PWM is modulating BUCK. How is the best way to achieve ?
Regards,
MArtin
led pwm
I've found a MAXIM chip that does what I want. MAX16802.
mc34063 350ma
i'm doing a research on lighting control using PWM so i need a buck converter for that.
plz help me in the design.
Hi Nepoli,
explain a lot.
search in www.educypedia.be and come back to talk more.
information of educy is very good for start a project.
700ma current driver circuit
Here is an Universal High-Energy LED Lighting System
Reactions: mandoa
    mandoa
mc34063 pwm
Hi all!
Maxim ic: MAX774
led pwm circuit
Pharo, thanks for this good info. Regards, Martin
constant current led pwm
martingn,OK and here is a schematic with 5 Luxeon or same led's.It's very simple!
Regards,PHARO
constant current pwm circuit
Pharo,
Could not open the last file. (0bytes)
Regards,
Martin
Added after 56 seconds:
Now I could!
Thanks!
Martin
buck current source
Martin,
I try and download it now and it's OK.
You push "Download" button only.
Regards, PHARO
