Why this Verilog coding used in testbench is wrong?
lostin_eda
Newbie level 6
Newbie level 6
About verilog coding
Hey, the following statement which is used in testbench, and i think it is wrong, right? and tell me why it is wrong thanks for your help
always @ ( a or b or c)
begin
if ( a)
begin
@ (posedge clock);
e = b;
end
else
begin
# 10 ;
e =c ;
end
end
Re: About verilog coding
@ (posedge clock);
kanagavel_docs said:
Plese describe your requirement...
Kanags
I just want to know that whether "@ (posedge clock )" could be added in the statement
if "a" is true "e" will be assigned with "b" after the rising edge of clock comes, but if "a" or "b" or "c" changed when waiting for the rising edge of clock?
This always block is sensitive to a, b, c inputs only. So tough to capture the rising edge of clock. If the clock rise and any one of the input change happens at the same time only the execution will move from this statement. So, add clock in the sensitive list and try.
Regards,
Kanags
    lostin_eda
Thank you all
i have run this code in ISE9.2i, but there is no error checked ,except no changes on signal.
