butterfish
Full Member level 2
My power supply is from 2v to 30v, I need design a bangap generate a 1.2v reference voltage, with standard CMOS process.
Any idear or paper? thanks for your help!
poweric said:the power supply is 30V this is too large the the MOS in the standard CMOS process cant work ,because it cant udertake the high voltage you should use BCD process in my view
DenisMark said:Generally U need preregulating BGR reference. It's LDO with Voltage Reference (Bandgap) supplied by output of this LDO. This solution requere suitable startup circuit.
More compact solution u can find in this paper (it can be easily adopted to HV process):
