a general purpose neuron implementation on FPGA
rakesh_vnit
Member level 3
Member level 3
india
hey...
i did a project on the neuron implementation on an FPGA. the neuron is especially useful for implementation of back propagation algo on neural network.
the vhdl code of the project is attached....
quite an interestin one....try it if u like.
hi,
interesting project, if you have any further documentation about neural networks on FPGA's, and a simple documetation about this project, it would be so helpful
hi rakesh, nice of you for sharing.
If you are still here on this forum...
I am just starting Verilog and do not know VHDL so I havent quite understood the written code but eventually will, hopefully.
Does the sigmoid use a lookup table?? Do you construct your own adders/multipliers or do you use existing structures on the fpga?
thanks.
Sir
U have provided very good project. I am doing my master of engineering and in my project neural network is going to utilise . So i have needed its documentation part. i will be very thankfull if you can provide it for me
Added after 2 hours:
rajivbit_23 said:
Sir
rakesh_vnit said:
hey...
Rakesh sir,
I am very thankful for sharing such a nice project. Sir but in absence of documentation it is tough to understand the coding and what exact the project is.
I am working on image processing using neural network. I will be very thnkful again if you provide me the documentation part:D
hii rakesh..if ur still here on this forum, can u help me to write vhdl code for sigmoid function..I am doing my project in artificial neural network..
