janlcc
Newbie level 5
uwb bowtie
I am trying to simulate a wide band patch bowtie antenna using HFSS. From the literatures, I found the UWB bowtie antenna falls into two categories, slot bowtie antenna with CPW feeding and self-complementary bowtie design. I want to design a patch bowtie antenna with both ties in the same side and as big as possible in comparing with the wavelength. Is it possible?
Can some give a hint how to design a bowtie antenna, such as the roles in the bandwidth, gain of the flare-angle and the dimension of the antenna?
Thank you very much!
jennifer
jennifer
