How to set the core_gen signal ?
kun
Every time when it data latched
on positive edge of clock it must be at the centre
anyone know how to do it
core_gen
What is "it"?
    kun
core_gen
Is this what you need? Center of Data is always at positive edge of the clock.
initial begin
for(i=0; i<256; i=i+1) begin
data <= d'd0;
@(negedge clk);
end
$stop();
end
    kun
Re: core_gen
question is not clear.
    kun
core_gen
negative edge of clock send data,
positive edge of clock receive data (maybe worry)
BR.
ls000rhb
    kun
core_gen
if u are talking with reference to Memory and your design interface,then use inverted clock for Memory when your design is working at clock.
    kun
core_gen
Anyone please help me :cry:
i need to create a Core_gen
which send the signal through a ADC ( Analog-to-Digital converter )
Anyone know how to set the core_gen Signal !!
list me the step please~
thanks
Re: core_gen
send signal through ADC? or send signal to ADC? detail your requirement, others can help you.
Re: core_gen
i need a signal Generator go in to ADC and come out with 10 bit Digital
anyone know how to do it please~~ :cry:
core_gen
Well Man!!!
Why u asling this question from FPGA men !!!!
ADC is very simple
IC's are available for that
and by the way FPGA works only on digital signals not analog ones !!!!!
YEs you can use an ADC chip before FPGA
and use ADC output to process for some information in it
and to build a simple signal generator use LUTs or Primitives etc in FPGA
or use Microcontroller for that
Even a DSP Processor would work
Do what u feel easy about
    kun
Re: core_gen
becos im noob to this VHDL :cry:
core_gen
yup i got the IC . just that i don know how to start on signal Generator .. ( if is a Core_gen i can still work on it ) but kind of different err anyone help
Re: core_gen
i need to link the output of the ADC to the DAC
meaning ADC output to DAC input ( 8bit to 8bit )
( anyone know how to write in VHDL )
anyhow please help ~~
Added after 5 hours 5 minutes:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity assign4 is
Port ( X : in STD_LOGIC_VECTOR (9 downto 0);
res : in std_logic;
m_clk : in std_logic;
out0, out1, out2, out3, out4, out5, out6, out7 : out STD_LOGIC_VECTOR (9 downto 0));
end assign4;
architecture Behavioral of assign4 is
type State_type is (S0,S1,S2,S3,S4,S5,S6,S7);
signal current_state,next_state : state_type;
Signal p0,p1,p2,p3,P4,P5,P6,P7 : STD_LOGIC_VECTOR(9 downto 0):="0000000000";
begin
process (m_clk, res)
begin
If res='1' then current_state <= S0;
elsif m_clk'event and m_clk='1' then
current_state <= next_state;
end if;
end process;
process ( current_state, X )
begin
case current_state is
when S0 => p0 <= X;
next_state <= S1;
when S1 => p1 <= X;
next_state <= S2;
when S2 => p2 <= X;
next_state <= S3;
when S3 => p3 <= X;
next_state <= S4;
when S3 => p4 <= X;
next_state <= S5;
when S3 => p5 <= X;
next_state <= S6;
when S3 => p6 <= X;
next_state <= S7;
when S3 => p7 <= X;
next_state <= S0;
end case;
end process;
process ( current_state )
begin
if current_state <= S0
then
out0 <= p0;
out1 <= p1;
out2 <= p2;
out3 <= p3;
out4 <= p4;
out4 <= p5;
out4 <= p6;
out4 <= p7;
end if;
end process;
end Behavioral;
Re: core_gen
jason here..wahaha...finally i graduate le....
u...better look after the newcomer worx...=D
    kun
Re: core_gen
WHAHA so nice done with the project . Mr Lai got say anything at the last day ( i was not there ) keke
take care my friend
Re: core_gen
hahas...u saw my project meh?? mr lai show u 1?? did he say anything about it??
actualli there are some flaws in the project...but i tried to cover it up..hahas..dun tell him worx....
mr lai didnt say anything on the last day...he juz say.."ok lahs...can...u can go now...good luck to ur attachment..=D"
Re: core_gen
wowow i was sick that day . so never got a chance to come and see.. keke soo good ^^ he still wish you good luck muahahaha . what are you doing so free now
Re: core_gen
jason
where are you
i need to ask you about DDS
help~~~
reply me asps
tmr afternoon i need to test hope you see this message
drop me email ( hey_56@hotmail.com )
how to make the DDS
8bit
120MHZ
10bit cannot test need 8bit
core_gen
That is quite reasonable......
core_gen
is it related to core_gen?
