Interfacing Bluetooth USB Dongle with Microcontroller
bluetooth dongle avr
Hi all ,
Can I Know , what's the meaning of "Dongle"?
Thanks in advance.
    V
vinculum bluetooth dongle
Hi every one there is lot of things i have learned from this dicussions. But one thing i want to know why is Bluetooth modules are more costlier than USB bluetooth available.
Are USB bluetooth suitable for industrial applications??
    V
bluetooth interfacing to microcontroller
Yes , Bluetooth can suiable for Industrial applications. But not for far away distance.
aproximately 200meter .alse Bluetooth via usb can work.
    V
interfacing of bluetooth with controller
Thanx farzad but my query was not regarding distance. USB dongle bluetooth devices available in computer shops work well under home enviornment but is this true for hazardous high temperature and humidity also.
    V
bluetooth hid microcontroller
@RSABear
Hey i think its a gr8 idea to start developin bt stack for windows platform...nd prob. wid small part of it...i.e. SPP....its really worth trying...let us know any progress or important matters regarding this......
    V
bluetooth microchip pic
Guys I already try using a bluetooth dongle interfacing in a PC. My project is electronic billboard via bluetooth. Which is PC based I done it, late 2006. It mostly programming basics and circuit analysis on how you sent data to the serial port.
Using a nokia cellphone, we have NOTES their. We can sent it thru bluetooth, and receive by bluetooth dongle in the PC. Notes can be converted so that we can sent routine to the port bit by bit.
rgds,
    V
cheap bcm2045 pairing
Hi bryan!
Can you clarify your last post? Your bluetooth dongle is connected to the PC through USB, right? Then you send data from your nokia cellphone through bluetooth to the PC?
    V
shingadaddy
dear niket
would you mind to change your concept?
If not u can use the nRF24 which has built in MCU with Blue tooth.
let me know your plan
thanks for sharing
feline
    V
usb bluetooth dongle mcu
how can i interface 89c51 ic with bluetooth dongle?
please suggest me hard ware and software part.
you can send me information/data sheets/circuit diagrams/programs on my email id nileshnesk@gmail.com.
please help me this is very important for my academics.
thanking you.
    V
bluetooth dongle to microcontroller
wow great schematic diagrams!!! i think i might use that for my thesis
bluetooth dongle and microcontroller
any other choice rather than the Max3421E?
microcontroller usb bluetooth
What about ISP1* chips from NXP? Especially ISP1160.
pic+bluetootrh usb
HELLO GIVE A CIRCUIT IMPLEMENTATION PLEASE...
bt dongle mcu
hai i also working on that interfacing broadcom Dongle to PIC 18F4550..
if any details how the dongle communicates with the USB
we can develop that in micro -- need to study HCI Commands
Added after 22 minutes:
here is the hci spec from bluetooth.org
i think many of the USB dongles are working with BCM2045 i got it from local shop here is the datasheet..
and HCI standard Manual
bluetooth usb 2.0 micro controller
hai guys
check out this link
Complete Bluetooth 2.0 Stack including
• Baseband and Link Manager
• Protocols: L2CAP, RFCOMM, SDP
• Profiles: GAP, SDAP, SPP
• High Integration: Includes Antenna, crystal, EEPROM, LDO
• Supporting up to 7 active Bluetooth data links and 1 active SCO link
• Class 2 operation
• UART Command/Data port speed up to 921.6kbits/s
• Advanced Audio Interface for external PCM codec
• Better than -80dBm input sensitivity
• FCC certified: FCC ID: ED9LMX9838
• IC certified: IC-1520A-LMX9838
• CE Self certified
• Bluetooth SIG QD ID: B012394
• Compact Size: 10mm x 17mm x 2.0mm
then what else you need to interface with a microcontroller...
let us try out it....
:D:D:D:D
bluetooth usb dongle code for microcontroller
Has anyone finished this app? I think it is hard to interface USB devices to micros, it jus sucks.
Get an RS232 bluetooth dongle, much better.
bluetooth hci command send to mcu
Veru useful thread... :)
bluetooth dongle interface to microcontroller
hi
i m working on a project where i m interfacing a MCU with bluetooth.
i will send some commands from my bluetooth enabled laptop and the bluetooth dongle fitted on MCU side(its USBport ) will receive d commands n will work.
just d whole idea of connecting dongle with laptop n sending commands is nt clickin??
pls help
wat kind of programming is needed?
and how will the mnemonics be converted into serial bits by the dongle to be understood by the MCU??
pls help
thanks in advance
usb demo board bluetooth
Hi people.
Did someone make it?
I'm trying exactly the same thing for my graduation project.
I have two options:
USB<->serial<->low cost microprocessor or
low cost bt dongle<->usb host controller<->microprocessor with bluetooth stack.
I will try the second one. If someone already made something like this please share the secrets.
Geek regards.
Luis Marcilio
uclinux bluetooth dongle
mmnetmohanedaboard said:
hai guys
check out this link
• Class 2 operation
• CE Self certified
:D:D:D:D
This would be perfect except that it is class 2 so range is limited if it was class 1 it would have been so nice.
