How to lock a box component in ADS software ?
jayce3390
Full Member level 6
Full Member level 6
Hi ,
Does anybody know how to lock a box Component in ADS software ?
thank you
Re: ADS
you will select the component after, click in red "X" icon , ok
    jayce3390
Re: ADS
Oh sorry, I will clarify, in fact I want to forbid someone to push into my component box because I have some parameters inside that could be disturb the box preformances.
I just want lock "the push into".
Thanks a lot
Re: ADS
You might be able to walk around this problem by using S parameter files for that component.
    jayce3390
Re: ADS
I have the solution, You can download RFIP Encoder from the Adgilent knowledge center.
If that can help someboddy....
Re: ADS
I don't how popular this tool is. Companies are usually very carefull with providing IP with this type of tools. In most case, NDA is still necessary.
