pads layout library : converting from 2004 to 2007 ?
seyyah
Advanced Member level 2
pads layout library
how can we convert .pt4 files into .pt7 :?:
converting pads files from pt4 to pt7
Pads 2007 has a utility to convert pt4 to pt7 libraries - look here \MentorGraphics\2007PADS\SDD_HOME\Programs\Libconv4_07.exe.
SiGiNT
    seyyah
pads 2007 library
Hi Sigint,
Assume you have lower version say 2004,then how to do proceed on the above subject...
Is it simply export the ascii file to the required one huh...i don't think 2004 ver supports to export it to the 2007 ver...
Regards,
Ramesh
converting to pads 2007 library format
Just follow what SiGiNT was saying, his solution is great.
