vkalariya
HI all
I am designing the Fractal antenna for the multi-band application.
First I design the antenna(Square patch) for one frequency that is 1.5 GHz and after that I want to design the same antenna radiate at 5.5 GHz.
But when I make that radiate at 5.5 GHz by making the iteration in square patch then my first frequency is changed to 1.3 GHz.
So, can any one say that why this happened ?
and
What is the possible solution of the problem. ?
and
