Please help me problem of antenna's radiation by simulation?
cuongtran
Full Member level 3
Full Member level 3
WhiteHouse
Hi all,
I have a problem when finished the simulation of patch antenna, please help me to verify results and verify the set-up if it is possible. The principe lope seems that do not in the direction vertical (with the patch plan), and the result has two lopes? I don't know why? I would like to have and I think that the patch can produces a smooth, symmetric pattern with little backward radiation...(I will still develope but now it is important to find a solution for problem above)
I will appreciate all your help... THANKS very much.
Help me problem of antenna radiation simulation
Has anybody tryed it for me; plz. I just think has it got the problem of the way of feeding point?
Re: Help me problem of antenna radiation simulation
up up
Added after 4 hours 10 minutes:
Cheked, result : false
Hi cuongtran;
İ looked at your simulation. i think the patch is so far from the ground plane. because of this, it has two main lobe.
    cuongtran
Hi asondas, I tryed to change the distance between patch and GND for smaller but the results is not better, I 'll play with the substrate thickness..
I ' ve played in ...., does anyone has comments?, you 're welcome..
