CST - draw ellipse problem
Chest
Member level 3
Member level 3
Dear all,
I'm facing problem with drawing ellipse in CST simulator. Anyone know how to draw the half ellipse? Thanks for helping.
BR,
May you can first draw an ellispe then draw a rectangle(half size of ellipse) then just a boolean operation.
It works
    Chest
Do you want to draw that ellipse just as curve? If so, CST allows drawing of any shape, that can be desribed by equation. I can't remember exact way, but it is described in tutorial PDF in install dir. I have constructed a parabola once this way.
It works
Thanks your help, I draw it finally.
Thanks, I know how to constructed by using shape, but I had mentioned is half of the ellipse. But you said using equation to constructe, I will figure out if have this way.
BR,
It is also possible to construct a half ellipse with help of the 2d curves (u need to take care of the co-ordinate) but it should be used for much complex curve lick for drawing vivaldi shape etc
Finally, I found it. You have to use VBA Macro. In menu choose Macros -> Construct -> Create 2D curve analytical. After choosing that, CST will construct some curve. Now you have to go to the History and than edit the VBA definition of made curve, there you can use parametric equation of ellipse and construct any part of it, in dependence of values of parameter.
