Using Code Coverage in Modelsim 6.2c
adsenthil
Newbie level 5
Newbie level 5
Hai all,
I using modelsim 6.2c windows version, im trying to use Code coverage for my design but im not able to check.can any one give tips or procedure to do this.
If have any document send to my email id adsenthil@rediffmail.com
Re: Code Coverage
tell me wot are you doing? are you compiling with "-cover bcestx" option?
i.e while u use vcom/vlog command you should use
vcom -cover bcestx (for vhdl)
vlog -cover bcextx (for verilog).
This will help you to collect coverage stats, while you do vsim
Then you should use
vsim -coverage <lib_name>.<tb>
like
vsim -coverage mywork.dma
hope it helps,
Kr,
Avi
http://www.vlsiip.com
