sc cmfb will generate great equivalent resistance, so that it will not affect the output stage gain.
Also by sc cmfb, other voltage than vcm can be feedback to the op, so that one cmfb op can be saved to enhance the cmfb gbw.
The most fundermental reason is that: ADC is a discrete time block, it has clock, so sc cmfb can be realized without defect.
