Is the VCO duty cycle always 50%?
dhasmana
Member level 5
Member level 5
Bangalore , India.
Is it true that the duty cycle of every VCO is 50% (assuming no variation because of PVT)? If we add inverters in the VCO for getting rail to rail output then they will add jitter due to threshold variations and thus duty cycle will drift away from 50%.Please comment in this regard.
Regards,
Jitendra.
VCO Duty cycle
Some times, a VCO does not have a 50% duty cycle precisely.
Adding inverters after the VCO, duty cycle will drift, I agree.
but I don't think the jitter is added by inverters, jitter is produce by VCO itself.
Ryan
VCO Duty cycle
Don't you think that drift from 50% duty cycle is same as jitter?This drift in duty cycle is a random process or a deterministic?I mean the duty cycle varies from cycle to cycle or just stays around a value away from 50%?
What is the difference between deterministic jitter and random jitter?I mean in terms of the origin /reason for their existence?
Regards,
Jitendra.
VCO Duty cycle
jitter does not mean drift in duty cycle, it means the variations in the zero crossings of the output clock, if you plot all the zero crossings at a single point you will gent to know the jitter.
amarnath
VCO Duty cycle
Can you please elaborate on "variations in the zero crossings of the output clock"
I did not understand this point.Do you mean the variation in the clock edge timing , i.e when is the edge apearing?
VCO Duty cycle
basically if your system is getting clocked onj postivie edge, then take the positive edge as a reference and then measure the varioations of the zero crossings with reference to this edge.
amarnath
    dhasmana
VCO Duty cycle
Ok.This is what I understood.Now if the +ve edge is reference and -ve edge is varying with time, then it also means that the duty cycle (from one cycle to other) will vary.These two phenomena are not independent I guess.Jitter will translate in duty cycle variation also?Please comment.
Re: VCO Duty cycle
If you look at datasheets, you will see that duty cycle are specified between 45% - 55% (sometime 40% - 50%).
Adding any component will increase the jitter. This is due to the thermal noise, flicker noise etc. of the component itself.
Jitter is not a drift, it is a variation (pseudo oscillation) from the ideal position. Your duty cycle will change 50% +/- jitter, but the mean value will be 50%.
    dhasmana
Re: VCO Duty cycle
Jitter will not translate in duty cycle variation as you thought. Jitter is said in one clock period, if +ve edge is reference, -ve edge change, and if we consider two -ve edge as one period, then the period will not change, because the -ve edge has changed the same. and jitter is generated. But the duty cycle has change, because the duty cycle is considering between +ve and -ve edge.
Ryan
VCO Duty cycle
how to simuliate jitter?
Re: VCO Duty cycle
The duty cycle variation is another term called DCD(Duty Cycle Distortion) jitter. Since DCD is bounded, it is a kind of DJ(deterministic jitter). In deed, DJ can be decomposed in to ISI, DDJ, DCD and PJ(periodic jitter).
As you may know, jitter from VCO output is unbounded, which means it is random jitter.
Therefore, unless you add extra logics(or circuits) in proper way, they may introduce some jitter, which may look like DJ. However, in general, RJ is dominant term in clock-like signal.
Re: VCO Duty cycle
Regards,
Jitendra.
the invertor definitely add jitter, however, it's very small
Re: VCO Duty cycle
To simulate a deterministic jitter, a simple way is to use frequency modulation around the main frequency. Not very realistic, but easy to make.
Electrocoop
Re: VCO Duty cycle
Ryan
no, you are wrong, the inverter will add jitter to the clock, because of the inverter has worse psrr
