What is setup time violation for the circuit?? Pls help
melryin
I have problem finding the settup violation for the circuit on the attachment.
Can anyone help to find the setup violation and how to fix the problem???
Thank you so much!!!
Can you make the question clear?
You haven't mentioned the clock period and the setup time for the registers
In your circuit when the clock period is greater than 11ns it works fine..
the question does not give any information on the setup time and clock period as well.
I was cracking on this for long time. THank you so much for pin point the lack info on this question!!
Really thank you so much!
