I have a Question !!!
hassan1980
Full Member level 4
Full Member level 4
Hi, all of you
By the way, I need your experience !
Actually I used assemply language for pic microcontrollers then I want to write program with high languages but I don't know what's the best one.
after I searching via internet I know that Proton Plus Compiler and the C compiler is the best then I want your suggestion, what do you prefer?
Hope to help me to choose powerfull compiler.
CCS C and High-Tech C are in my opinion the best, but you will pay for them, both have student versions with limitations. I use both each have strengths and weaknesses. Both companies realise this and you can now produce Object file for inclusion in the other, a bit like DLL/lib files.
    hassan1980
Download MPLAB C18 ot C30 compiler student version.
It will work like a full version for 60 days.
You can check its performance within 60 days.
If it is good for you then order full version.
    hassan1980
hbaocr said:
hi, I'm newbie about C laguage for PIC!
If you don't mind plesea send to me some document about writng CCS C for PIC. thak very much
This is not the right place to request for PIC ebooks, documents or tutorials.
    hassan1980
pic C is the best software as far as i know
    hassan1980
Hi
c is better beacause it is middle level language and coding with c is very similar to coding with assembly.
    hassan1980
