bluesmaster
Member level 3
I want to use the PNP in standard cmos process as levelshift. How about the match?
will it get the same match as the vertical pnp in bicmos process?
I not sure wether the match is relative to the Gm. In bicmos , the gm of pnp is
very high. So the offset is small. But in standard process, it is very small.
Anybody can evaluate the match of the bulk BJT, and the influence in the Bandgap design caused by the mismatch.
