differential amplifier can suppress even order harmonics?
katrin
Full Member level 1
Full Member level 1
I often read that the fully differential amplifier can suppress even order harmonics,
but I don't really understand why.
Could someone explain it?
thanks
Re: differential amplifier can suppress even order harmonics
For any amplifier:
Vo=a0+a1Vi+a2*(Vi^2)+a3*(Vi^3)+a4*(Vi^4)+a5*(Vi^5)+............
where a2,a4,a6,....... are the even harmonics coefficients
while a3,a5,a6,........ are the odd harmonics coefficients
Since the sign of the input will not appear in the even harmonics terms as it is always raised to the power of an even number, thus at the two outputs of the differential amplifier the even harmonics are the same(assuming perfect matching) and thus when the two output are subtracted(differential output) the even harmonics on both sides will cancel each other.
it is cancalling at the output because differential output is Vp-Vn
But if the circuit has any mismatch between the two sides of the differential pair, the even harmonics will show up at the output.
so, exactly speaking, because of device mismatch, fully differential amplifier cann't completely suppress even order harmonics, just reduce them to a low level.
    katrin
"For any amplifier:
while a3,a5,a6,........ are the odd harmonics coefficients "
I really don't know are they true or not.
"Since the sign of the input will not appear in the even harmonics terms as it is always raised to the power of an even number, thus at the two outputs of the differential amplifier the even harmonics are the same(assuming perfect matching) and thus when the two output are subtracted(differential output) the even harmonics on both sides will cancel each other. "
can you explain more please?????
