What are the job requirements for a front-end ASIC engineer?
shiv_emf
Advanced Member level 2
What r expectation of company from a FRONT end ASIC engg ??
I am fresher Mtech student !!
reply plz
regards,
shiv
ASIC engg
no reply:O
i wonder y ?????
ASIC engg
hi,
1.) Be strong in the tools ( using u have done projects)...
2.) Strong logic and strong in Analog and digital basics..... ( mainly required for design jobs)
3.) Knowledge of ASIC and FPGA design flows.
4.) Keep urself updated with current trends ( solutions ) provided by EDA companies such as hard ware acceration concepts , prototyping solutions etc ....
With Regards,
    shiv_emf
Re: ASIC engg
Hi,as ASIC engineer,generally companies expects good digital and analog basics and also design flow from RTL to GDSII.and also be perfect with tools u have by working out atleast 5 projects.
bye.
    shiv_emf
ASIC engg
for a fresher MTech student, just the digital basics and verilog/vhdl will do for front end
    shiv_emf
Re: ASIC engg
gbaerf said:
hi,
With Regards,
very helpful reply !!
keeping updated with current trends ... u mean reading white papers or going through eda tool vendor websites n checking out latest developments !
thanks
Shiv
Re: ASIC engg
Hi
Though u are a fresher companies expect u to know some of the tools. U should be good in digital design with verilog in case of digital and
analog design with pspice is on the analog side
and u should also be experieced with some mini projects or main project in ur degree level. and u should be 100%fit to be answered on your academic project and u should be thorough with that project.
and should be good in answering basic level of questions in vlsi like cmos design.
Finally u should be thorough in basics of vlsi
    shiv_emf
ASIC engg
hi shiv,
Exactly u are right ,
just check the following links I have attached some of the solutions " that will give u more ideas for which i was talking about" new solutions from EDA tool vendors,
with regards,
    shiv_emf
ASIC engg
As a fresher you should be good in basic digital electronics,Verilog/VHDL.
Fundamental knowledge of Anlog will help you at great extent.
    shiv_emf
Re: ASIC engg
Basic things u need to know include
1. Basic Digital Electronics
2. Verilog/VHDL programming basics(Basic theory)
3. What is ASIC & FPGA ?
4. Tools used in full front end flow.
But dont try to understand much about tools if u want to be in front end vlsi. But, if u want to be on EDA front, better understand tool concepts.
    shiv_emf
