banjo
Advanced Member level 2
xilinx usb jtag
The simple circuit for connecting a parallel port to the Xilinx JTAG programmer is readily available on the web and works fine. However, my laptop does not have a parallel port. I tried a couple of "Port Replicators" but these use a chipset that does not allow any bi-directional operation.
I stumbled across one adapter that uses the MOSCHIP, MCS7705. From the datasheet for the chip, it seems fully capable of being used as a bi-directional port. However, I am having lots of problems getting Windows XP to load the proper drivers.
1. Is anyone familar with this adapter?
2. Has anyone gotten it to work for direct accesses to the LPT port for programmers like the Xilinx? If so, can you tell us the tricks? Can you report what version of driver you are using?
Again, while this device shows promise, I have not gotten it to work yet. The manual for the device states that it will work with scanners that run in SPP mode. (The port replicators that failed for me all say that scanners are not supported.)
This device seems to be available on the web. Below is a URL .
Thanks.
----- Steve
Thanks.
----- Steve
