How can I increase the swing of a unity gain amplifier?
ahmed709
Junior Member level 1
How can i increase the swing of the unity gain amplifier, i tried to increase and decrease the (W/L) of the transistor but the swing is not very good.
thanks in advance
Re: Unity gain amplifier
have u checked its delay times
i.e.
its risetime and falltime
time period
check these things also
    ahmed709
try increasing the biasing current... it would help.....
    ahmed709
Could be your opamp is limited by the input common mode range. Try to increase the slew rate of your opamp, that is by increasing the biasing current, which will help in fasten the rise and fall times.
    ahmed709
Increase the tail current of the differential pair can increase the slew rate. But you have to check the phase margin.
    ahmed709
