salem_eng1
Hi All
I am working nowadays in system design of PLL frequency synthesizer for ZigBee.
From my search on the net and e-books I found some specs but not all I need so any one has this specs or have a simple tutorial for the ZigBee standard and its Physical layer please upload it
The specs I have :
-fc=2405+5*(k-11) MHz , k=11,12,........,26
-frequency range: 2.4GHz<fc<2.4835GHz
-Frequency tolerance: 40ppm
-Channel spacing=5MHz
-Channel B.W=2MHz
-Settling time=190usec
-Phase noise : -80dBc/Hz @ 3.5Mhz , -75 dBc/Hz @ 5Mhz , -105 dBc/Hz @ 10MHz
The specs I need
-Minimum SNR at the receiver input
-Minimum Rx power.
-Maximum Rx power
-spurs level at 5,10,15 MHz offset
My question is that I am not sure from the specs I have so any one can correct it to me if there is any mistake or tell me how to check it is right also I need the other specs I don't have can any one tell me how to get it
Thanx
The specs I have :
-Channel B.W=2MHz
The specs I need
-Minimum Rx power.
-Maximum Rx power
Thanx
