sundarmeenakshi
Full Member level 3
ANTENNA IS ACTIVE DEVICE OR PASSIVE DEVICE?
BUT ANTENNA also we are using some booster?sundarmeenakshi said:ANTENNA IS ACTIVE DEVICE OR PASSIVE DEVICE?
BOOSTER IS AMPLIFIER? THEN WY WE ARE TELLING BOOSTER? WHAT IS THE DIFFERENCE BETWEEN BOOSTER AND AMPLIFIERA.Anand Srinivasan said:yeah we use booster to boost the signal the antenna receives.... you gotta understand that the booster is not a part of the antenna but just something which follows the antenna which is used to amplify our input weak signal....
OOO THANK YOUsundarmeenakshi said:BOOSTER IS AMPLIFIER? THEN WY WE ARE TELLING BOOSTER? WHAT IS THE DIFFERENCE BETWEEN BOOSTER AND AMPLIFIERA.Anand Srinivasan said:yeah we use booster to boost the signal the antenna receives.... you gotta understand that the booster is not a part of the antenna but just something which follows the antenna which is used to amplify our input weak signal....
