MikroC and Hi-tech C error
bbgil
Full Member level 2
Full Member level 2
_delay_ms function declared implicit int
Hi guys,
I have this question on why Hi-tech C is giving out the error while Mikro C is not. the code is very simple. I'm familiar with assembly language but just started out with c. I'm trying to see which is easier to use between the two.
void main() {
PORTC = 0;
TRISC = 0;
while(1) {
PORTC = ~PORTC;
Delay_ms(1000);
THe errors in Hitec c are:
Severity Description Resource
Id
2 (499) undefined symbol: _Delay_ms
1 (361) function declared implicit int line 25
20
1 (337) line does not have a newline on the end line 26
1 (176) missing newline line 27
is it syntax error? and why is it looking for missing new line when its already the end of the program? Any help is appreciated.
(499) undefined symbol: _delay_ms
hi,
delay_ms() is a built-in function of Mikroc , In hi-tech c it doesn't have a built-in function named delay_ms()
    bbgil
hi-tech portc
#include"delay.c"
void main() {
TRISC = 0;
PORTC = 0;
while(1) {
PORTC = ~PORTC;
Delay_ms(1000);
regards
:D
    bbgil
function declared implicit int 361 hi-tech
thanks for the replies. What about the error on the end of line. that one confuses me. any particular way that c in hi-tech be ended differently than in mikro C? i thought c is c in any compilers.
hi tech c missing mew line
Try this
Give a new line at the end of the code.
That means
Click at the end of your code ( after } //~! ) and hit the enter key
