saif haider
Full Member level 1
i made a dipole antenna and when analyzed i got the desired result now i want to make another dipole antenna at distance of lambda/4 to first dipole. what shall be best to have the dipole antenna at the desired distance. i used the DUPLICATE>MIRROR command but their was no use so i move one to array command, i used REGULAR ARRAY command but it also not help me getting the desired result
