How to install IC5141 on ubuntu 7.04?thanks.
holddreams
Full Member level 6
Full Member level 6
Shanghai
ic5141 ubuntu
ubuntu ic5141
The same procedure as other Linux system
    holddreams
ubuntu install ic5141
maybe if you actually say what is the error you will get better answer
    holddreams
ic5141 on ubuntu
/opt/IC5141/tools/dfII/bin/icfb.exe: relocation error: /opt/IC5141/tools/dfII/bin/icfb.exe: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
ic5141 glibc 2.5
I don't think it's possible to run 5141 on 7.04, because glibc 2.5 doesn't support LinuxThreads, unless you re-compile the glibc...
    holddreams
install ic5141 ubuntu
Any other way to install?
I find that unbuntu is easier to use.
ic5141 ubuntu installation
i have this problem as well in fc7 and 5141. i installed ic610 in fc7 and it worked but i am more familiar with 5141 so i wanted to go back to that.
how to install glibc_2.0 in ubuntu
are you planning to learn Ubamtu or IC5141? If you just want to learn Ubuntu then stick with Ubuntu, if you want to learn IC5141 then switch to RHEL2.1
