How to invoke the Xilinx ISE 8.2i tool?
shiv_emf
Advanced Member level 2
how to invkoke Xilinx ISE 8.2i
>xst
or
>ise
what is the command? i tried to C proc in user guide of xst .. but no use
do v need to set any environmental variable??
i am working on linux redhat!!
shiv
Re: Basic Question
in command prompet
    shiv_emf
Re: Basic Question
Follow these steps
create a file called YourFile in /usr/local/bin ie( /usr/local/bin/YourFile)
copy your settings file to a YourFile
export your Display properties to Yourfile
export "exec ise" to YourFile
Change the permissions of YourFile
now you can invoke the tool by using the command YourFile
(Note: YourFile is the command to invoke the tool.You can give your own name instead of YourFile)
