How to measure phase noise in ADS?
Sadegh.j
Advanced Member level 3
I have designed an oscillator and I want to measure it's phase noise in ADS, what simulation can be used? How can I ask ADS to the measurement?
Re: Phase noise in ADS
Hi Sadegh.j,
Harmonic Ballance simulatiom will solve your problem. In the attached file, go to ch3. I think this is what you are lookin for.
Hope it helps,
    V
the HB is the simulator for phase noise
u should frist adjust the HB with the oscport , to dtect the oscillation , then select noise analysis by adding the noise controller , and specify the frequency range of analysis and the output type , and plot the pnmx , this is the phase noise , also u can plot the amplitude noise
khouly
