msadek_eng
![Full Member level 1](/styles/images/ranks/elevel1.gif)
this project will scan 8 line with 8 RGB leds per line and will provide a 8 bit PWM for each led , how to ???
msadek_eng said:there is an error about the current consumption , you assume that i will turn on all the leds and this is not true the consumption will be 8x3x0.02 = 0.48 Amp using row scanning with duty cycle of 1/8
