Harmonic distortions in an ideal sine wave
jiangxb
Full Member level 3
Full Member level 3
hangzhou, china
hi
i use a ideal sine source in cadence to output a sine wave, and process it in matlab to plot it's psd, as below
this is a ideal sine wave, but there are the 3rd and 5th harmonic distortion. why?
(i use hanning window. if no window, the harmonic distortion exist yet)
Re: harmonic distortion
Hi
The harmonic distortion may be related to the way you are saving cadence results.
Please give more details, how are you saving cadence data for matlab processing?
    jiangxb
there is no HD3 , HD5 if you use ideal sine wave in MATLAB,
the result u got probably come from some numerical , or truncation process.
    jiangxb
hi analogy and Btrend
thank you
i have found the cause. i use ocnprint to output the data from cadence, and use the default precision, 6, so have truncation error. when i set precision 10, the result is correct.
