lyzrdstomp
Junior Member level 2
- Joined
- Apr 13, 2007
- Messages
- 20
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Midwest US
- Activity points
- 1,448
zener diode resistor
I want to use a 12Volt zener diode and a resistor to bring an unregulated 36V input down to 12 volts to run a 12V/110mA fan. I used the calculator here:
Entering the values 36 for input, 12 for Zener voltage, 110 for mA, it says I need a 200ohm resistor at roughly 3 watts.
For a bit of safety headroom, would a 5 watt resistor be sufficient for this or should I go for an even higher wattage one?
Just making sure before I order parts.
