subramanyam said:All the asynchronous signals like reset , preset , clear are used for the purpose of sending the system into a known state in the initial condition. If reset is not used then definately flipflop output will be in any unknown state in the initial condition.
If u don't use them the flipflop won't go into any metastable state. I think using an asynchronous signal itself may cause the system to go into this metastable state ???
subbu.
shiv_emf said:what are we gaining by not having RESET in FF?
routing will be improved ... high fanout reset net length is reduced
is thr any power or speed gain ?
Area of FF mite be less
Shiv
dft_guy said:However, be careful, because, you would never want to hope for the same when design a state-machine. FSM's must always power up in a known state.
DFT Digest
