sdf123
Newbie level 1
Hello everyone,
I am working on a keypad logger DIY project which is quite simple to someone with experience, but for a newbie like me, it's a hughe task, so I hope someone can help me out a little bit.
The target of the project is like this:
Make a stand-alone 4x4 keypad with battery and circuit which can record the every keystroke on the keypad and with time stamp. The data will then be transfered to computer after certain amount of data has been recorded. The connection method can be usb, rs232 etc. Also the circuit board is expected to be as small as possible to fit in the keypad casing.
Thank you.
Thank you.
