safwatonline
SC CMFB
how to check the stability of sc CMFB ?
Is it true that the SC CMFB doesn't add pole to the loop?MSSN said:As far as I remember , the SC CMFB by itself is always stable(it doesn't add poles to the loop), what u need to check is the stability of the rest of the CMFB loop.
safwatonline said:i meant being discrete time how to see PM and GM , do poeple usually use PSS + PAC or what?
