NOORPURI
Junior Member level 3
I am trying to interface Kingston MMC card 256MB with AT89S8252/S53 microcontroller in SPI mode using SPI port in
MODE 0. I used 74LVTH244 for level conversion from 5 volt to 3.3 volt for MMC I/o.
I send CMD 0, CMD1 & CMD 16 . I found proper & desired response from MMC side according to standard. Then i try to
read CID & CSD registers. Then after issue command there was no data tonen i.e. 0xFE. I commnect this step then i
found Kingston MMC card give with packes with header of 0xFFFFFC at both packets.
After when itry to Write a sector , MMC give me proper responce after issue commnad. But fater write a sector it
does not give me any vaild /invaild acknoledgement .
Similerly when i tried to read a sector then it didnot give me a proper data token.
